time2roll wrote:
And all this time I thought they pumped at night and generate in the afternoon.
That's reversed if the need is to provide a water battery for solar energy storage: Use the electric motors to pump the reservoir full when the sun is available so you have pump motor power ... and then whenever the sun isn't available or the reservoir is full enough, let the water drain from a higher level reservoir into a lower level reservoir through the reversed rotation pump motors to make electricity.
The anti-reservoir crowd shouldn't care - in fact they should endorse the method, being that a lot of them are sustainable/renewable energy types anyway - because the "reservoirs" are only used for the temporary storage of water in two locations that can be very close to each other. The only water "used up" would be that through evaporation and leakage, which could be replaced from outside sources periodically as needed. The reservoirs would be very access and use controlled and have nothing to do with boating, fishing, swimming, or the sustaining of wildlife ... just like with "drinking water supply" reservoirs that can't be accessed or used for anything else. Of course a couple of huge tanks could serve the same technical purpose ... but I'm assuming that earthen reservoirs could be constructed to hold way, way more water for energy storage than any man-made tanks.
IMHO, water movement between two high-low reservoirs to act as temporary storage of vast energy from the sun is a perfect solution to the sun's fickleness impact on widespread solar energy use. Let's get on with it everywhere possible ... the large solar farms need not even be physically close to the water batteries.
