WileyCoyote214's avatar
Aug 06, 2013
Bent frame and suspension issue
Long story short...
I have a Cyclone 5w Toy Hauler (1 year old and 11k mileage) that had a tire wear issue. Took it to the local authorized dealer/service shop for alignment who determined the suspension hangers were layed-over in different directions and binding. Also they noted the right frame I-beam was "bent" above both rear axles, in addition to having a cracked weld on the opposite side cross member. In their opinion it was a manufacturer defect and they also would be unable to repair the suspension due to the frame bending (description below). I took it up with Lippert and their reaction was to deny a problem.
After consulting 2 more QUALIFIED shops in the area and hiring a forensic engineering firm (Insurance Company)... the consensus was the same: Manufacturing Defect leading to suspension failure, leading to tire damage. Now Lippert agrees to look at it and they transport the coach to their factory.
HERE IS THE KICKER...
Lippert says the frame has no damage and that the "frame flexing" is "normal". In my case, if one puts a straight edge to the frame I-beam above the tandem rear axles, there is a "wave/bend" in it that measures up to 1/2" from trough to apex.
I have a hard time believing that they manufacture frames that are supposed to bend. In addition I have spoken with 2 authorized dealers, who have over 100 years combined experience in RV sales/service, only to hear that none of them know of any such "flex allowance" in the frame. There is a tolerance for a frame being out of square, however that is not the case with mine.
I have religiously weighed the RV to make sure it's not overloaded and still have the scale receipts. The coach has also not been in any type of collision/road hazard incident, nor has it been turned in excess of 75-80 degrees.
MY QUESTIONS TO YOU ALL:
- Have you heard of such frame damage from NORMAL use?
- Have you heard of an "allowance" for frames to bend/distort due to normal use?
Thank you for your advice and experience in advance!
  • Lippert strikes again.
    A few weeks ago they made a big deal about how one of their divisions "now" uses nothing but certified welders. Which means that before that they were welding frames, without being certified.
  • There is a tolerance for normal frame flex. But it's so minimal you would never notice it. Its usually caused by parking on uneven surfaces. Nothing near what your experiencing. And normal YEARS of use and rot will cause flex. Not at 11k miles..
  • Wiley Coyote, I had a 28 Layton and put lots of miles on it including a coast to coast trip one summer three years ago. The frame broke and bent to beyond repair. The insurance co. totaled it out because it was going to be too expensive to fix. The box would have had to be lifted off and a new frame installed. Cheaper to buy a new trailer. So that's what I did. Bought a 30 ft. Forest River Toy Hauler BP. The wheels where under sized and I broke 5 wheels before having to replace the 6 lug 15" to 8 lug sixteen inch wheels on it. No problems since. As a matter of fact, Forest River compensated me for the upgrade. I really feel good about their help with this problem.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
