jplante4
Dec 15, 2019Explorer II
rk911 wrote:
in case it makes a difference to you AvGas is low lead not no lead...fyi
I pump a lot of 100LL this time of year into 5 gallon containers. Just a warning; if you have a Honda engine, it's ok to use 100LL to store it, but don't run more that a tankful through the engine. The valve clearance on Hondas is tight enough so you'll get lead buildup and a stuck valve.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
