SDcampowneroper
Dec 16, 2019Explorer
Cummins12V98 wrote:JaxDad wrote:Cummins12V98 wrote:
I am curious why some run premium when their small engines only require regular gas?
Simple. Most premium fuel is also ethanol free gasoline.
In bigger engines the benefits go far beyond not having gummed up carb’s, the net cost per mile is lower running premium gas than regular gas.
The increased fuel mileage exceeds the increased cost per gallon.
Someone smarter than me can please explain the above is simply not true.
Me too, I would like to see some proof of cost over cost. High octane fuels are needed for high compression motors to prevent pre ignition, Knock. Here. where I live at high altitude, low octane (85) ethanol gas gives equal mileage to 91 pure in vehicles. Cant see a difference in performance either. SDDOT.GOV results.
Back to OPs question. Ethanol fuels absorb moisture from atmosphere as ethanol is a dessicant and the resulting water contamination can be a serious issue.
Ethanol is an alcohol 1 of 7 miscibles that dissolve in any amount of water.
So your beer may be a near beer (.05 %) or an 190proof Everclear. Thats what ethanol is is a highly distilled grain alcohol. It loves water and can turn your gas into 10 % near beer.
I use 87 octane 10% ethanol in regular drivers with sealed tanks, 91 no ethanol in seasonals like boat , snowsleds, mowers, Harley, and 100LL av gas in all 2 cycle tools.
Never a stabilizer. Some sea foam for fun at beginning of the season for that machine.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
