drsteve
Dec 17, 2019Explorer
MDKMDK wrote:Son of Norway wrote:
I buy pure (no ethanol) gasoline that I keep on hand in a couple of 5-gallon cans for snow blowers, lawn mowers, power washers, portable generators etc. The STABIL products that I buy indicate their use for alcohol-blended fuels. Are there any fuel preservatives specifically for pure gasoline and which one would you recommend? Thanks for your help.
Agree with Old Wizard - unless you go through a 5 gallon can once every decade, I probably wouldn't worry about it going bad. Even stored for that length of time it will probably still work.
Honestly, I tried fuel stabilizer about 10 years ago, and there was no noticeable difference in the fuel quality that I put it in, versus the last 10 years of not bothering. I've left ethanol laced, and pure dino, gas in my shed over the winter and it still works, when I use it next year in the mower/tractor.
Some believe that some engines might prefer you use it all up, to dry, before long term storage. However, I've never done that either, and had no problems.
Same here. I use 10% ethanol regular pump gas and no stabilizers, and I never have an issue. Been doing it this way for many years.
Every piece of power equipment produced in the last 10-15 years is ethanol ready.
When it comes to lawn mowers, string trimmers, power washers, etc. there is no advantage to premium fuel, non ethanol gas, or stabilizers, in my experience.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
