harold1946
Apr 27, 2013Explorer
pianotuna wrote:
Hi,
Let's get back on topic--which is Poly or Mono in low light.
We have a statement rule of thumb from a seller, that suggest mono gets the edge.
We have a real life test where the poly whipped the mono by a fairly substantial amount.
So folks poly or mono?
Just so as you know I will ask a mod to remove any post that does not address the above.
Lab testing and tier scale indicates poly.
Manufacturers and sales persons make many unsubstantiated claims.
If poly and mono are the only choices it would be poly.
Given the other alternative I would choose the hybrid with its higher conversion efficiency.
Does giving an alternative constitute failure to "address the above"?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
