HiTech
Apr 27, 2013Explorer
harold1946 wrote:
Hi Tech; Semantics again??
Is the definition of good in an RV application different than say a residential one?
Common sense tells one that efficiency of all PV drops off as light deminishes and varies by latitude and angle of installation, atmospheric conditions, no matter what the materials used in construction.
But common sense does not say the drop off is equal nor linear across two panels or panel types.
Yes an RV application is quite different. The RV moves from place to place and is subjected to a much larger and less predictable variation in light level and orientation than a residential install, where you can understand say partial shading and design for it very specifically.
You can call definitions semantics, but I say you are hiding behind semantics to try to do an apples to oranges comparison, claiming that it is semantics to point out that an orange is not an apple. After all, they are both fruit. They must be the same, right?
Jim
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
