harold1946
May 01, 2013Explorer
pianotuna wrote:
Hi,
Misleading information, panels intended for charging a 12 volt battery are never 12 volts. Very optimistic numbers. Even worse if pwm is used. MPPT has conversion losses of between 2 and 4%, and losses increase as input voltage rises.harold1946 wrote:
Watts = amps x volts. cant have one without the other.
a 12 volt, 256 watt panel is capable of producing 21.3333 amps maximum.
12 volt, 460 watts will produce 38.3333 amps maximum.
How is it misleading? the formula is the same, just change the volts to Unisolars spec of 16.5 volts and calculate for 256 watts.
256/16.5 = 15.5151 amps maximum. at peak output. Or what ever voltage trips your trigger.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
