HiTech
May 01, 2013Explorer
harold1946 wrote:
I have heard many claims over the years about this or that panel being superior, but the fact remains, if one is using more than can be produced, the only answer is to produce more, and the answer to that is an array that will produce the most power with the available realestate.
I basically agree, but my take would be *enough* power *under the actual conditions the solar panels are in*. Or possibly under the worst case conditions you care to plan for.
That seems to be the difference in the approach. Design for specific conditions that are different than nominal, or select technology for nominal conditions and just keep getting more until it meets your actual conditions often enough.
Jim
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
