ctilsie242's avatar
ctilsie242
Explorer II
Sep 13, 2017
Best PEX fitting system?
I know what the first thing people say when it comes to PEX fittings, and that's Sharkbite/Gatorbite/etc. However, with those, there is only a single O-ring that can easily get nicked if one isn't careful inserting the tubing, and the O-ring will get eaten away over time by chlorine. Either way, you have a leak.
Crimp fittings are commonly used by RV makers, but twist the lines slightly, and they start to leak.
So far, the best I've found is Uponor's ProPex expanding fittings, which only work with their PEX-A pipe, and their expansion tool is not cheap.
Second best appears to be Flair-It fittings which assemble and disassemble by hand, and because they squeeze the PEX tubing on all sides, it does a good job.
What would one recommend for RV plumbing?
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
