valhalla360
Nov 04, 2018Navigator
Check for loads when you disconnect shore power: 15 minutes to dead after disconnecting means you either have a heavy load or the battery was already toast.
You don't say what size battery it is but your winter use is likely drawing too much before recharging. TV/Lights/Ceiling fan could easily be pulling 20amps. At 6hrs, that would add up to 120amp-hr. For a single dual purpose battery, that's likely leaves it completely dead before you recharge.
Going below 50% charge on a lead acid battery typically does damage.
It's possible you have something on in the RV that is damaging the battery but my bet is the winter use.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
