red31
Nov 04, 2018Explorer
mrad wrote:red31 wrote:mrad wrote:
I usually check water in spring and fall and have not had to add so tht should not be the issue.
a death of repeated undercharging.
What do you mean by undercharging????
From reading the posts, I it looks like I ran the battery too low before charging, but the battery always received a full charge before being used.
Your JCI iterstate likely requires 14.8v (bubbles and water loss) held constant for extended period of time to be FULL it might take more from time to time, hydrometer.
http://www.trojanbattery.com/tech-support/battery-maintenance/
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
