mrad
Nov 04, 2018Explorer II
MEXICOWANDERER wrote:
OK I need more info. You are stating the Vector has no float or was configured to default to never go less than 2.2 amperes charge rate. The Vector is capable of continuous 2.2 amperes output?
Not sure about the float. Te charger say 12/6/2 amp charger. The digital readout shows how many amps the charger is putting in. If I set it at 12, it will show 12.3 for quite a while and then slowly drops. It will show as low as 0.1 on the display.
It will kick on and off when I have it hooked up in the basement, starting at 2.2 an quickly dropping to .9 and goes lower until full
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
