MEXICOWANDERER
Nov 04, 2018Explorer
This battery has 25% more capacity than a deep cycle group 27
https://batteryguys.com/products/lifeline-gpl-31xt
http://www.megawattpowersupplies.com/
The two items would do the trick provided you do not accidentally or or purpose drain even more power overnight.
- Setup on the Megawatt is easy I'll help you via private message. You will need a digital meter and a tiny flat screwdriver. Adjust Megawatt once for all time
- How easy it to use?
- Plug it in when you get home then disconnect it anytime the next day. Proper care is a snap
- Not need to maintain it in the off-season. Charge it and leave it disconnected. No need to remove battery, just disconnect the negative cable to the trailer. The Megawatt stays disconnected during the off season
- This ad says it ships direct to your door step
- But the main thing thing is this is a way better setup and the 100.00% full recharge is goofproof and no screwing around with dials and gauges. Plug it in for the night.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
