- pkunkExplorer
Vulcan Rider wrote:
What equipment has that FL1 terminal......and what and why are you trying to connect to it ??
Pair of new replacement 110AH 12v AGM batteries for the house system. - DrewEExplorer IIII'd use a ring terminal held on with a bolt and a flat washer/split lock washer/nut. The ring terminal and the battery terminal should be in contact, with no washer intervening, assuming a permanent attachment. For a battery charger or similar temporary connections, I see no reason why the usual alligator clamps would not be perfectly adequate.
- Vulcan_RiderExplorerWhat equipment has that FL1 terminal......and what and why are you trying to connect to it ??
