wopachop's avatar
wopachop
Better AC filter for those who havnt seen it yet
Done this the last couple summers with a household filter. Its the black label from Lowes. The different sizes are the same price, so get the 20x30 (or largest you see) if you decide to try it.
I remove the foam filter and the plastic screen. Last year i used a wind meter to measure air speed coming out of the vents. That was with a smaller filter last year and it didnt seem to restrict flow.
Also last year we had lots of fires. People were putting these filters on the back of a box fan to filter the air. Not the worse idea.
  • Gdetrailer wrote:
    Pleated filters like that are considerably more restrictive to air flow than the original washable foam filter.
    Agree! The original style were there for a good reason. You are not doing your A/C unit a favor. These units were not made for that filter.
  • Pleated filters like that are considerably more restrictive to air flow than the original washable foam filter.
    It is good that you checked air flow but even a slight restriction under the correct conditions may result in the A/C cools to freeze up into a solid block of ice much faster than they would otherwise.
    I use those filters on my wood burner fan box to reduce wood ash from getting blown through the house. I modified the fan box to use two filters in fact side by side and even that causes a noticeable change in air flow.
    I won't even consider them on my home furnace, causes the furnace to trip the overtemp limits once and a while..
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
