MEXICOWANDERER
May 30, 2019Explorer
If you should open one of those adapters you would gag when you see the connections inside. Now with a simple 120 vac soldered plug I can plug into a tight receptacle and it'll do for a night or three. With gloves I can replace a receptacle with a USA 77 cent Home Depot replacement using my electric screwdriver in under a minute. Then I can run a 5,000 BTU air conditioner from any receptacle. Cools the bedroom.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
