brulaz's avatar
brulaz
Bicycle Lock Vs Angle Grinder
We're boondocking, and after having lost a battery to thieves I'm keeping everything locked up.
But now the bicycles' U-lock jams. It's a cheap barrel key with a pin that broke off inside. The bikes are locked together and to a steel picnic table in the middle of Ocala NF.
Turns out there are reasonable quality 6.2A angle grinders available for US$40 (Hitachi at Lowes). Fitted with a metal cutoff disc, and running off my 1000W PSW inverter, that lock was cut off in no time.
Of course thieves can do the same thing ...
Anyway, I'm permanently adding that tool to my RV tool box. You never know when you might need to cut or grind some metal.:B
  • JaxDad's avatar
    JaxDad
    Explorer III
    2oldman wrote:
    Sprink-Fitter wrote:
    2oldman wrote:
    Boondocking is about the safest place you can be.
    How is that?
    Fewer people, fewer criminals. Criminals are lazy too, they don't go driving long distances to seek out victims.
    That's my theory on sleeping in highway rest areas instead of Wallydocking.
    If they have a vehicle, gas money and time to get out to a rest area they're less likely to be as money-hungry as the folks in the Wally-world parking lot.
  • A friend destroyed the jaws on a brand new 48" made-in-USA RIGID® bolt cutter. He did not believe my 1/4" manganese steel square link chain stood a chance. So he grabbed a Makita 4" grinder with a saw disc. It exploded the disc.
    Have a stainless steel (316 is best) box built to pass the chain through and use a good padlock. No it isn't bullet proof. But a thief dragging a 120-pound Rottweiler using his butt muscles makes light fingering rather a discouraging endeavor.
    EDIT: Inclusion of "RIGID®"
  • The aftermarket guarded hasp and lock they use of van doors are really very good. Very difficult to attack even with a grinder. Sadly many of the "name brand" companies use cheap, relatively easy to pick, lock cylinders. (A good lock pick, working a lock he has picked before, is almost as fast a bolt cutters on a chain.)
    If you are going to buy one of these, get one with a thick steel guard and the key on the bottom.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
