landyacht318's avatar
landyacht318
Biggest converter for Honda 2000
I am trying to assist someone else.
They are getting a Honda 2000 watt generator.
What is the biggest converter that it will be able to handle when charging 3 pair of depleted GC 6v batteries, lets assume 1500 feet above sea level?
Thanks
  • Fisherguy's PD9280 drops to 75a at start and settles between 75-70 for a time before tapering off. (like a typical PD) that might help with the generator. ISTR the gen has some sort of surge allowance above that 1600 continuous for a certain time, which might be enough time for the PD to taper. However I don't know if it wouldn't run a straight 80 anyway. The PD9280 needs a 20a circuit not a 15a circuit.
  • BFL13 wrote:
    I think Fisherguy runs his PD9280 (non-PF corrected) with his. Probably can run the PF corrected PowerMax 100amper or WFCO 68100.
    For near max load with a cold gen I recommend leaving Eco off at first, then turn Eco on a few minutes later.
    I know the PD60A runs fine and gives the honda some margin, that's what I have. When I looked, the powermax PF corrected 100A should also work fine, maybe even better than a PD60A. I considered the PD80A, and couldn't convince myself I'd be able to run it at a full 80A. Problem is/was that PD doesn't spec VA draw, only watts, so it's a guessing game. I guessed it would be near the honda 1600VA max. but couldn't determine if it would be "above" or "below", so I went the the 60A.
    However if Fisherguy runs his, sounds like it's an option and you've got a definitive answer. However, anything more than 80A Non PF corrected probably is going to be a problem.
  • I think Fisherguy runs his PD9280 (non-PF corrected) with his. Probably can run the PF corrected PowerMax 100amper or WFCO 68100.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
