- ScottGNomad
Dave H M wrote:
I have never seen or heard of a glue in waste valve before?
Mine have always been the undo the four bolts and slip the new one in there. :h
Something new every day.
That's what I was trying to get them to do in my post. People are hung up on replacing the pipe flanges, which of course is totally unnecessary.
Scott - Dave_H_MExplorer III have never seen or heard of a glue in waste valve before?
Something new every day. - smthbrosExplorerHome Depot sells "Socket Saver" 3" for $13.22
Menards sells "Saver Reamer" 3" for $8.99
Just in case you need one. - opnspacesNavigator IIICut and replace
Yes - Artum_SnowbirdExplorerMy rig has a flexible 3 inch rubber connector between the 3 inch plastic pieces. Had to replace both of them just after I bought it (The old story... we never used the toilet or the shower) Yeah right. Anyway, each piece is a standard household connector readily available. They come with two screw clamps and are easy to install.
- Colo_NativeExplorerYou can not unglue, You can however cut it and use no hub clamps from your local Home Depot or Lowes. I did this with mine so I could replace the 3" waste valve. Just make sure you cut it straight as possible.
- Cummins12V98Explorer IIIThere is a tool to cut old pipe out of a ABS fitting. Don't think you want to spend that much $$$.
If you have a bad glued in valve simply buy the same open it up and remove the center slide portion and seals and install in old valve.
