CarnationSailor's avatar
Jun 03, 2021
Black Tank Dump Valve
When I dump a full black tank, the valve opens very easy, no problem. I flush the tank for 5 to 10 minutes, then I close the valve for 5 minutes to let it partially fill. When I then pull the handle to open the valve again, it is so difficult that I almost cannot open it. Been this way for a couple of years, and now I thought I might do something about it.
I put tank valve lubricant in the tank periodically, but that doesn't seem to make any difference. Any ideas why full it is a piece of cake to open, and after flushing and partially filling, you almost need a gorilla to open it.
  • Might try spraying handle/metal rod with silicone. Or probably just need to replace. I did my tank, took me about 3 hours.. but I got it done.
  • Something in the seal dries out over time and then swells with usage? Regardless why not just replace the valve and be done with it?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
