D_E_Bishop's avatar
D_E_Bishop
Black Tank Ordor Solution
We have a 2002 Winnie Adventurer 32V. Last week when dumping before heading for home, there was a very strong odor from the black tank both outside and inside the rig. A day or two ago, I had the vent fan on outside the WC and all the windows closed and once again the odor. Turned off the fan and opened a window, odor gone in a few minutes. This evening I had both vent fans running and the kitchen window open and the window behind the swivel rocker open. Came out a couple hours later and the same odor but, much less strong.
Both tank vents have vent checks adjacent to the vent riser. Both risers have roof caps.
The kitchen sink is separated from the WC by some cabinets and the range and I can only find one riser on that side. This leads me to suspect the sink drains to the black tank.
I have not had a chance to rinse and clean the sanitaries as we just bought the rig and I am unable to do much due to a Lumbar Epidural this morning. I usually only use water in both tanks, except when storing and have not had this problem with the Bounder we had. I will flush and try the Calgon method to clean the tanks when I can but in the mean time what can I look for? A broken vent pipe, dislodged or broken pipe fitting in the vent system. Plugged vent pipe. Make sure the vent checks are sealing.
This evening when I turned the vent fans off the odor when away very fast.
Just checked again, there are 3 Roof Vents
Solution.
Following to suggestions here, one of which I was kinda thinking about last night and one that I didn't realize was so bad. I pulled both Vent Check(valves) removed the valves and cleaned the seat and valve face covered with waterproof plumbers grease, the other is the water is draining out of the bowl, just not at the rate I thought. It drains very fast. I cleaned the ball and tighten the gaskets and that slowed it down a little. I can now run the Fantastic Vents with door and windows shut.
Thanks for the suggestions, I have ordered the seals and will remove, clean and polish the flush ball, lube well and hope t holds, otherwise it's another $38 for the flush ball and fittings.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
