Old-Biscuit
Oct 11, 2015Explorer III
Topic: Black water toilet plugged
Posted By: Happycamper30 on 10/10/15 09:42am
Does anyone know how to unplug a toilet we use Rv'ers tissue.
Happycamper30 wrote:
Mine seems to be by the black water valve I pull on the valve handle the valve shows it to be open because the rod moves under neath the belly but my question s since the holding tank is full how do I manually pull the flapper valve back without a mess
Thank you
So your toilet isn't plugged ?
It's the tank drain valve not opening?
Tank drain valve........you need to access the valve. If you have an enclosed underbelly that means cutting a 3 sided window (access panel) so that you can use a pliers on valve shaft and pull it open then you can repair valve if possible or replace as needed.
