rockhillmanor
Jun 20, 2017Explorer II
Mine kept leaking even after replacing the valve blade.
Come to to find out that there were hair line cracks around the bolt openings that you really could not see unless you really got under there up close to look.
These hairline cracks would let it leak and it would run down and make it appear that it was the valve blade.:R
RV repair guy says he sees that all the time since the sewer lines coming out are free hanging and bounce around while traveling causing the hairline cracks around where the bolts go in.
When he went to take the valve blade out again the bolt opening actually cracked in his hands!
Had to cut and make a new sewer connection fix to add the new bolt holder, because that is a straight line pipe to tank. So check your bolt holes for hairline cracks regularly!
Never a dull moment RV'ing. :(
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
