Vixen21
Dec 01, 2015Explorer
Mex: I think it already answers your question:
Mains Operated LED Circuit Schematic
Posted Apr 17, 2013 at 1:44 pm
Small in size! Big in use
Here is a simple and powerful LED circuit that can be operated directly from the AC 100 volt to AC 230 Volts mains supply.
100Vac to 240Vac 50Hz or 60Hz Operated
Here is a simple and powerful LED circuit that can be operated directly from the AC 100 volt to AC 230 Volts mains supply. The circuit can be used as mains power locator or night lamp etc.. The resistor R1,R2 and capacitor C1 provides necessary current limiting. The circuit is sufficiently immune against voltage spikes and surges.
Circuit’s pictures:
Front View of 220 Volt AC Operated LED Circuit
Circuit diagram:
Mains Operated LED Circuit Diagram
Parts:
D1 = 1N4007
D2 = 1N4007
D3 = 1N4007
D4 = 1N4007
R2 = 1M-1/2W
R1 = 470R-1/2W
C1 = 220nF-275vAC
D5 = 5mm. Blue LED
Features:
Small in size!
Blue LED operated on mains voltage
Suited for mains indicator or other pilot lamps
For safety guidance, stairs, corridors…
Special X2 safety capacitor
Dimensions: 28×18mm / 1.10 × 0.71”
Note:
Only for use inside a cabinet
The capacitor C1 can be polyester type.
Also white LED can be used in this circuit.
Assemble the circuit on a general purpose PCB.
Safety and Hazard WARNINGS:
This circuit operates on a lethal power voltage. Mount the circuit in a protective cabinet prio to applying AC Power. Do not modify the circuit – Wait 10 minutes before touching the circuit after disconnecting the AC Power. This circuit is not intended for retired children without a working internet connection.
Circuit’s pictures:
Circuit diagram:
Parts:
D1 = 1N4007
D2 = 1N4007
D3 = 1N4007
D4 = 1N4007
R2 = 1M-1/2W
R1 = 470R-1/2W
C1 = 220nF-275vAC
D5 = 5mm. Blue LED
Features:
Small in size!
Note:
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
