Bobbo wrote:
Gdetrailer wrote:
Bobbo wrote:
A solid check engine light means check the codes whenever it is convenient.
A blinking check engine light means pull over, stop and call a tow truck.
No, not even close.
2008 Chrysler Town & Country Manual wrote:
19. Malfunction Indicator Light
This light is part of an onboard diagnostic system
called OBD that monitors engine and automatic
transmission control systems. The light will illuminate
when the key is in the ON position before engine
start. If the bulb does not come on when turning the key
from OFF to ON, have the condition checked promptly.
Certain conditions such as a loose or missing gas cap,
poor fuel quality, etc. may illuminate the light after
engine start. The vehicle should be serviced if the light
stays on through several of your typical driving cycles. In
most situations the vehicle will drive normally and will
not require towing.
If the Malfunction Indicator Light flashes when the
engine is running, serious conditions may exist that
could lead to immediate loss of power or severe catalytic
converter damage. The vehicle should be serviced as
soon as possible if this occurs.
emphasis added
LISTEN UP FOLKS.
THE OP'S VEHICLE IS NOT A CHRYSLER.
Chryslers and Fords CEL lights OPERATIONS MEAN DIFFERENT THINGS, PERIOD.
Ford calls it SERVICE ENGINE SOON LIGHT.
DIRECTLY FROM FORDS OWNERS MANUAL
HERE one page 13 of the Ford owners manual it says..
"Service engine soon:
The Service engine soon indicator light illuminates when the ignition is first turned to the RUN position to check the bulb.
Solid illumination after the engine is started indicates the On Board Diagnostics System (OBD-II) has detected a malfunction.
Refer to On board diagnostics (OBD-II)in the Maintenance and Specifications chapter.
If the light is blinking, engine misfire is occurring which could damage your catalytic converter.
Drive in a moderate fashion (avoid heavy acceleration and deceleration) and have your vehicle serviced immediately"The indicator light in question looks like THIS..
It is only ONE COLOR and only has TWO "modes".. Solid ON and BLINKING.
Folks, please quit "comparing" other manufacturers CEL light functions to how Fords CEL light functions..
INSTEAD QUIT "ASSUMING" AND READ FORDS MANUAL BEFORE SPEWING A BUNCH OF WRONG INFORMATION....
The OPs vehicle is not going to self destruct with a CEL light blinking or on.
On edit..
stew47.. I would highly recommend you go to
FORD TRUCKS ENTHUSIASTS FORUMYou will find nothing but FORD OWNERS WHO ARE MORE THAN HAPPY TO HELP OTHER FORD OWNERS instead of someone who "knows a owner of a Detroit Diesel" or a Chysler owner or a GM owner or a Toyota owner just making guesses at what a simple indicator light means for YOUR vehicle..
I AM a Ford owner of not one but THREE trucks with 5.4s, a 2003, 2006 and a 2013.. I can honestly tell you that this entire thread is filled with a lot of misinformation and it didn't come from me..
