weathershak
Oct 23, 2015Explorer
I used an air compressor once. I just use my water pump to blow the lines. First I drain the water tank and water heater. Then bypass the water heater. I turn on the pump and let it run. I open the low point drains until no water comes out. I close them for a minute, then open them again. Some residual water and air comes out. I close the drains, then check all the faucets and shower and make sure just air comes out. After that I run the pink antifreeze thru all the lines using the syphon hose attached to the pump.
The last 2 years, I had to make the decision a couple of times to evacuate to a Motel when temps dropped to the single digits. It was too darn cold out to use a compressor. :E
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
