dougrainer
Oct 24, 2015Nomad
wa8yxm wrote:
The black may have been oil or algae in either case it was NOT being blasted into your water lines. Air was being blasted into the water lines
The air tank allows water (Which is a product of air compression and de-compression) to settle into the bottom of the tank.. This is why they provide the drain.
NOT TRUE. The moisture and any other liquid debris in a Air Tank WILL come out the air hose in mists or spurts. It does NOT just sit on the bottom of the tank. Doug
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
