riggsp
Apr 25, 2018Explorer
Only way to get to the air filter on a Boliy generator is remove the two side panels (4 screws each) and the rear engine cover by removing two rear bolts (13mm Head) on the carry handles, some screws on the bottom rear (I think 6), and 4 inside screws ( 2 on each end that connect to the rear cover).
The air cleaner is directly behind the battery, held in place by two 10 mm head bolts...It has a washable foam filter.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
