larry_cad
Mar 15, 2021Explorer II
The simple and typical way to handle that is to have an inverter on your battery to produce 120vac. Then you can run your generator to recharge the battery through the inverter (assuming it has a charge function). You don't have to run the genny 100% of the time, just long enough to recharge the battery. An added convenience feature would be to install auto-gen start which will turn on and off the generator as needed. This makes best use of what you already have.
Certainly there are other systems, but as you said, not ready for solar yet.
