enblethen
Jun 20, 2013Nomad
Why did you use a trickle charger? Your converter should be keeping coach batteries charged. A trickle charger would be normally connected to the chassis battery to keep it up. Older converters can over charge the battery causing loss of water in battery. Check to see what make and model of converter.
Some coach manufactuers use the Ford trailer power to isolate the different systems. You need to see what isolation unit was used on your rig. Many diode based are in a blue or silver colored box about 4X5 inches with any where from 3 to 5 terminals.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
