dougrainer
Sep 19, 2022Nomad
I think you need to state more clearly. DON'T say flashed. If you connect 12 volts to either the Left or Right, they will NOT flash. They will be lit, but not flash. If they DO flash, with constant 12 volt, that is a whole other problem. You can have a smashed/cut 7 way cord from the trailer. Have you check that? Most common cause is the Wrong bulb/s in the rear trailer light assbly UNLESS you have LED trailer rear lights. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
