Cindywas's avatar
Cindywas
No blinkers, brake lights or cruise control
We have a 2006 Fleetwood Southwind. We have no brake lights, turn signals, or cruise control. We believe we need a new switch. We tried changing the fuses but they keep blowing. We believe the problem started when we tried to use our emergency flashers. Is there a way to bypass or come up with a short term solution until we can get this fixed. We are on the road and stuck. Thank you
  • You can consider checking the wiring connections at the switch or related components. Ensure they are secure and free from any corrosion or damage. If you find any loose connections or obvious issues, you may be able to temporarily fix or bypass the problem by securing the connections or using electrical tape.
    However, I would strongly recommend seeking professional assistance to properly diagnose and fix the issue as soon as possible. Joining a https://apkinu.com/jt-whatsapp/ group where you can receive updated information and advice from fellow RV enthusiasts could be helpful, but it's important to consult with a qualified technician who can provide accurate guidance based on the specific details of your situation.
    Safe travels and I hope you're able to get your electrical issues resolved soon!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Often brake lights and turn signals are two different fuses but it is clear if the fuse keeps a popping you have a short. Might be a switch. Might be a wire. Might be a light socket.
    Cruise will not work if brake light circuit not properly working.
  • "Most" Cruise control systems will NOT work if you have no Brake lights. So, once you find the Brake Light problem and it is fixed, odds are the cruise control will work. If you have a Ford Chassis, Brake Pedal Brake light switches are usually the problem if the fuses are OK. But, a defective switch will not cause the fuse to blow. Does the fuse blow ONLY when activating the Brake pedal? Or does the fuse blow when activating the Turn signals? Do you have amber or RED rear turn signal lights. Are you positive you have "released" the emergency 4 way flasher button? If still engaged and the lights do not flash that points to a defective 4 way flasher relay that may be the source of the short. There are 2 flashers. Turnsignal and 4 way flasher. Also which fuse/s blow? Turnsignals and Brake lights are on separate fuses. Doug
  • Cindywas,
    May I suggest a mobile RV repair person be contacted?
