dougrainer
Sep 21, 2022Nomad
Boon Docker wrote:nickthehunter wrote:
The positions are labeled the same, but the colors are all different; hence you would be putting the wrong color wire on the terminal.
I stand corrected on the color code.
The chart on Etrailer's website is the same as the one Bucky posted. Could Etrailer be wrong?
Etrailer Link
There are 2 different versions of a 7 way Bargman. I posted the CORRECT one for RV's. I have no idea what the other version is used on. Also, 4 way flat(utility and boat trailers), the Yellow IS Left and the BROWN is Clearance and the GREEN is right. But when people try to update their 4 way flat to a 7 way, they use the wrong colors on the pins. Over the years it always seemed to be CW and U haul that screwed this up when wiring vehicles. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
