Boon_Docker
Sep 21, 2022Explorer III
dougrainer wrote:Boon Docker wrote:nickthehunter wrote:
The positions are labeled the same, but the colors are all different; hence you would be putting the wrong color wire on the terminal.
I stand corrected on the color code.
The chart on Etrailer's website is the same as the one Bucky posted. Could Etrailer be wrong?
Etrailer Link
There are 2 different versions of a 7 way Bargman. I posted the CORRECT one for RV's. I have no idea what the other version is used on. Also, 4 way flat(utility and boat trailers), the Yellow IS Left and the BROWN is Clearance and the GREEN is right. But when people try to update their 4 way flat to a 7 way, they use the wrong colors on the pins. Over the years it always seemed to be CW and U haul that screwed this up when wiring vehicles. Doug
Good to know what is correct. Thanks for the update.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
