mchero's avatar
mchero
BOTH roof AC units running on a 20 amp power source?
I still can't figure out how this is happening! I had done this exact same procedure couple weeks back so I thought I would document the procedure.
I'm connected to a 20amp outlet in the garage., about a 30" heave gauge extension cord to the 50 amp cord.
Walking into the Discover I see the EMS system drawing about 7 amps. I shutdown the charger & I'm not at 5amps
set both AC units to cool with the fan on auto.
After a minute the #1 AC fires up & I see the amps spike to about 22 and then drop down to 10amps I hear the one compressor startup & the amps spike above 20amps for a second then drop down to 15 amps.
OK, I climb up on the roof, only rear compressor (AC#2) running) I climb back down, drop the thermostat on AC 1 to 70 deg.
Climb back on roof BOTH AC's fan AND compressor running. Back in coach BOTH AC's on & blowing cold EMS showing both AC's WITH compressors going drawing 17 amps. Looks like the EMS sheaded the HWH and Norcold fridge.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
