Lady_M_and_Fred's avatar
Sep 07, 2013
bounder wiring problem
Hello. My 97 Bounder developed a 12v short and blew a big fuse. The local shop fixed that, but now my 12v to the cabin lights and accessory panel is missing. They work when I'm plugged into hydro.
It should be easy to fix, but I don't have any wiring info. I've checked every fuse I can find with an Ohm-meter. HELP !
Keith.
  • In the battery control center, located under the hood should be two circuit breakers. They could have tripped.
    Try cycling your AUX battery disconnect. Turn to the off position and then back to on.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
