Huntindog
Aug 14, 2017Explorer
joebedford wrote:The way to measure WP flow is to measure it directly off of the pump.Huntindog wrote:
How did you measure the flow?
I looked at it - it's unacceptably slower than it used to be.Huntindog wrote:
Every TT I have had flows much better on city water.
No surprise there, as it SHOULD flow better.
Maybe your line from the tank to the pump is collapsing/kinked.
Doing it any other way can lead to a false diagnosis as the restriction can be in other places. Like the aerator screen of the fixture, or the the filter on the pump etc. If the new hose does not fix it, then you will need to look at the other possibilities since the diagnosis method is flawed. Your hose has likely been like that since it was installed.
So I doubt that is the cause.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
