Huntindog
Sep 09, 2017Explorer
Harvey51 wrote:I went into the utilities compartment to find out why the pump is slow to prime and slow to build pressure once all the taps are turned off. This seems like a possible culprit to me.
This is the symptom of a pump membrane failure. I took a picture of my pump's model/serial plate and asked for help at an RV store. The clerk knew exactly what I needed. The install was easy. The old membrane looked okay but replacing it solved all those problems.
Glad you got it fixed. I hope it stays fixed for you.
I did that repair once on my first TT, and it was only a temporary fix. It soon acted up again. Obviously there was an underlying cause. I just put a new pump in at that point.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
