joebedford's avatar
joebedford
Nomad II
Aug 12, 2017
Braided PVC for water pump collapsing??
The fresh water pipe that runs to the water pump from the valve to control draw from tanks or antifreeze hose is collapsing - makes water flow on pump poor. Any easy way to stop it from doing this? I'm thinking several gear clamps to keep it round. . .
. . . maybe shorten it a bit?
  • Harvey51 wrote:
    I went into the utilities compartment to find out why the pump is slow to prime and slow to build pressure once all the taps are turned off. This seems like a possible culprit to me.
    This is the symptom of a pump membrane failure. I took a picture of my pump's model/serial plate and asked for help at an RV store. The clerk knew exactly what I needed. The install was easy. The old membrane looked okay but replacing it solved all those problems.
    Glad you got it fixed. I hope it stays fixed for you.
    I did that repair once on my first TT, and it was only a temporary fix. It soon acted up again. Obviously there was an underlying cause. I just put a new pump in at that point.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
