Dusty_R's avatar
Dusty_R
brake away brakes
Question about the brake away battery/controller.
I had a 16' flat bed trailer, with brake away system. If the pin got pulled the brakes came on. You needed to check the battery once in a while, and recharge if necessary?
I replaced that trailer with a new 20' and the brake away brakes on that one have a battery charger built into it. Problem is if I don't unplug the battery when not in use the battery will run down.
Is there something wrong with it, or is that the way that are?
Thanks,
Dusty
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
