Dusty_R's avatar
Dusty_R
brake away brakes
Question about the brake away battery/controller.
I had a 16' flat bed trailer, with brake away system. If the pin got pulled the brakes came on. You needed to check the battery once in a while, and recharge if necessary?
I replaced that trailer with a new 20' and the brake away brakes on that one have a battery charger built into it. Problem is if I don't unplug the battery when not in use the battery will run down.
Is there something wrong with it, or is that the way that are?
Thanks,
Dusty
  • It charges while driving, if I don't forget to plug the battery back in.
    Dusty
  • Disconnect the charger....see what happens. If its the charger running it down, maybe a different charger,....or just use a charger when needed
  • I'd suspect the charger is not working if the battery still runs down.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
