joe0508's avatar
joe0508
brake bleeder tool
Can you use a brake bleeder tool to bleed the master cylinder while it is still on the vehicle?How would you do it?I know i can do the calibers with one and plan to but i have read to do a brake bleed correctly you should do the mc first before going to the calibers.
  • Old-Biscuit wrote:
    Check master cylinder level......needs to be full
    Then starting at the brake farthest away from MC bleed brake fluid thru it.
    If you have a vacuum pump........follow directions that came with that pump
    Keep MC topped off.....if it goes empty/sucks air into system you have to start all over
    Changing fluid completely.....suck old out of MC with turkey baster then fill with new.
    Bleed each wheel position until new fluid shows up (Keep that MC full)
    Start at farthest postion
    This is what i am prepared to do.I am just wondering if it is necessary to bleed the mc first?
  • Check master cylinder level......needs to be full
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
