MudChucker's avatar
MudChucker
Brake Controller / electric hydraulic brakes
Hi folks.
I have a 2015 Ram 3500 with factory integrated brake controller - it seems to work fine with my 5ver and other electric brake trailers.
I bought a brand new deck trailer with electric hydraulic brakes and am having some issues in that I cant get the brakes to work.
I have a neighbor with a 2015 Ram 2500 with the same factory brake controller and all works as it should, press the brake and I can hear the hydraulic motor start to run.
While I was at the trailer manufacturers shop they plugged in one of those socket tester gizmos and on my blue wire (brake power) we see the LED flickering and pressing the brakes doesn't change that behavior.
I have the settings in the dash set to heavy electric over hydraulic brakes and the truck detects the trailer.
the trailer also came with one of those modules that are supposed to resolve the issues with various brake controllers - unsure what it does but given that the brakes work with my neighbors truck Im guessing its not an issue.
I do have a splice in the factory socket harness to place a second socket in the bed of the truck. Dirty connection maybe ?
Looking for some troubleshooting ideas, do any of you have a 2015 ram 3500 and wouldnt mind metering your socket and tell me what the behavior of the brake power pin looks like ?
Cheers.
  • ScottG wrote:
    Can't really just meter it out. There has to be a load present so the controller thinks there's a trailer there. The meter alone wont do that.
    Need to make measurements with the trailer connected.
    good to know.
    any other thoughts ?
  • Can't really just meter it out. There has to be a load present so the controller thinks there's a trailer there. The meter alone wont do that.
