s_N_s's avatar
s_N_s
Brake light issues
I'll try to keep this as simple as possible. At the rear of the coach I have the 7 pin receptacle. I plug in my 7(which is actually 6 pin as the center is blank) pin to 4 pin adapter and it has right and left turn signal and marker lights but does not activate the brake lights thru the adapter. ???? Am I missing something here? I've always thought that the turn signal pins are the same for the brake lights. The brake lights on the back of the coach work. I should mention, I do use magnetic lights on the toad but don't see that should effect anything.
Hope this isn't to confusing.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
