s_N_s's avatar
s_N_s
Brake light issues
I'll try to keep this as simple as possible. At the rear of the coach I have the 7 pin receptacle. I plug in my 7(which is actually 6 pin as the center is blank) pin to 4 pin adapter and it has right and left turn signal and marker lights but does not activate the brake lights thru the adapter. ???? Am I missing something here? I've always thought that the turn signal pins are the same for the brake lights. The brake lights on the back of the coach work. I should mention, I do use magnetic lights on the toad but don't see that should effect anything.
Hope this isn't to confusing.
  • Are the turn and brake lights separate or is it the same light on your coach?
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 01, 2025
