fantasy_islande's avatar
Mar 26, 2020
Brake Lights
Doing a check as we prepare to leave for home, and the brake lights are not working. No voltage on the power lead, 20A fuse is good. FTL raised rail chassis.
  • Thanks to all for prompt replies.
    I also found no power to the hitch brake pin.
    Both fuses are good and have 12V.
    I now remember that the brake did not disconnect cruise when we came down.
    I agree that suggests a defective switch, but I've looked at the pedal area, and the only connection I see coming out of it is the pedal motor.
    I looked at the firewall, but there are a thousand wires, and I have no idea what the switch should look like if it's there.
    I'll call FTL for direction.
    Thanks again.
  • Optimistic Paranoid wrote:
    If you're SURE the fuse is good, I'd be checking the brake light switch next.
    Brake light switch at pedal and the ground.
    Brian
  • Is there power at that 20A fuse when you check with a meter?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
