moe_f's avatar
moe_f
Brake Magnet Wire Color
This is a question relating to the 'power' delivered by electric brake magnet.
There is a lack of information on the internet or elsewhere about the strength of brake magnets. After discussions with the technical experts at RV /trailer parts suppliers I have had responses that range from 'they're the same ' ' they're different', ' manufacturers use what wire is on hand', etc.
My question relates to my Jayco 5th wheel(GVWR 11,300 lbs.) which uses 5.2K axles and the magnet has white wires. I wish to improve braking on the unit by upgrading to 7K assemblies some of which use a white wire magnet while others use black wire magnets.
Can anyone share any experience you may have had with this or lead me to a credible source of information as to the relative strength of brake magnets by color of the electrical leads to the unit.
I have tried looking at / for government sources but have come up empty.
thanks
  • Doesn't matter. The magnet is a coil. Power goes in one side and out the other.
    That's all.
    B.O.
  • I just checked, my old 7,000 brakes have white wires. The new ones have white.
  • RAS43's avatar
    RAS43
    Explorer III
    Call Dexter axle and talk to a tech. They are very helpful whenever I have called. I am not sure if wire colors are different but I do believe there are different strength magnets.
  • The wires are interchangeable. Color isn't important. The best thing you can do is get self-adjusting brakes to replace the manual adjustment. The power is determined by the current supplied to it.
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Sep 02, 2025
