jfkmk
Jul 01, 2015Explorer II
The level in the master cylinder will get lower as your brake pads/shoes wear. However, it should never get low enough to cause the brake warning light to come on. Sounds like you have a leak or bad master cylinder. I would top off the brake reservoir with fresh brake fluid and pump the brakes to see if they come up. If they do, you can probably chance driving it to the repair shop. If not, have it towed.
