The bigger the wire the less voltage drop you will have. Using 12g is fine. 10g is better. 8g is better still, and so on. Use the largest wire you can comfortably use. Second the suggestion to use only marine wire.
Personally, I wouldn't go smaller than 10g.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
